Re: RogueTwo Robots
Seen quite a few updates and videos of robot testing today. Things here have taken a step back though.
When testing Drumroll to make sure that everything was still running fine, I noticed one side of drive wasn't working. I reckoned it was the pinion gear that had come loose on the drill motor shaft (and I was right) but in the process of stripping it down I had to butcher the wheel nut insert. Tried to re-do it this evening but didn't work too well, so switched to the Banebots hybrids I had for back-up. But one of them is off-centre slightly so the robot drives poorly going forward and just spins around one wheel going backwards. Basically, out of four wheels, I only have one reliable one, and the nut insert on that is starting to show signs of loosening up. So I think some steel hubs with the nut inserts welded on and with wheels bolted to the hubs is the approach I'll have to take.
Also stuck the batteries for the MDF bot on charge and, despite the chargers supposedly having some form of basic auto-detect feature, they managed to overcharge the batteries and one of the packs started hissing and was too hot to touch (similar problem happened at Barnsley a couple of years ago, for those that remember). I'm not sure if it's the chargers or the packs, as I charged Carcinus' packs on fast charge the other day without any problems, and they're the same style of pack. So I think I'll need to sort out getting a few more of the intelligent chargers with display screens to cut down on battery distruction.
To cut a long story short, currently the only working robot is Carcinus, which still needs its armour redone. I was supposed to meet up with Tony tomorrow to put the bots through their paces but have cancelled that to focus on fixing everything. The MDF bot is now low priority as I have no spare battery packs, so I'll try and get it running (by borrowing Carcinus' packs after it loses ) but only if I get the other robots finished first.
These last few build days were supposed to be relaxing, but now is when everything is going wrong
Better than having it going wrong in the arena I guess.
 ) but only if I get the other robots finished first.These last few build days were supposed to be relaxing, but now is when everything is going wrong
