None yet, been having too much fun playing around with my beetle
I've been holding off sorting out all ant-related stuff until my wages come through; it's psychologically less painful to order a bunch of robot bits when you're rich and expensive orders don't seem to make much of a dent in your balance!
Having said that, I've just noticed that I've only got this weekend and next weekend to get everything together, so I'll need to set aside some time this week to work out exactly what I need and get it all ordered. I expect the build to be fairly quick but I'm anticipating a couple of chassis revisions before I'm happy with it, so I just need to make sure I factor that into my build time. Don't want to be giving Eric a bad name or anything by putting in a shoddy small-scale performance
I know what you mean, I was just thinking that there isn't much time left and that you might have started but I suppose 2 weeks is plenty of time to build a robot in a class you've never built a bot in before...
Not to the best of my knowledge, but I've been wanting to get a fully working beetle built for a while now, so that if an event is announced at short notice, I can just turn up with my robot and go TA-DA!!
There's not a lot happening full-combat wise in the last quarter of the year (that I'm aware of anyway) so unless something comes up, I'm half-toying with the idea of trying to organise some sort of gathering or event (maybe beetleweight) just as an excuse to crack out the spinners and keep the battle juices flowing.
Got to turn this pile of parts into a working antweight (EricA) and fleaweight (mini Chaos 2). EricA is going to be driven by two 30:1 Solarbotics motors, one of which is missing in the picture as Technobots is awaiting delivery of more stock - just hope it arrives in time. These will be attached to the wheels in the picture (32mm diameter) and at 6V will be pretty damn nippy. Just going to use servo boards out of some surplus/crap servos as speed controllers, as I've got plenty kicking about. The battery pack is 120mAh and will also be powering either a 20g servo or a 14g servo (with metal gears) for the front lifter. I've got five A4 sized sheets of 1mm polycarb there and a sheet of 1.5mm ali that will be used in varying amounts as the chassis/armour.
The mini Chaos is getting new drive servos as the current ones are just too underpowered. The blue servos on the left of the picture will be the replacements - TowerPro SG-50s weighing in at 5g each. The smaller of the three battery packs (4.8V, 120mAh) will provide the power, and with a smaller FrSky receiver, everything will fit in the back and allow me to get the polycarb cover on it. I'll need to trim the flipper plate to get it to fit the 3 cube but it'll be a cut-and-shunt job so it will still look the same. It won't be that effective but will be good fun to drive around
Jonny: It's a drawing of a full-body spinner yeah, but I don't think it'll come to much. I drew it to the 4 sizing just to see how big it would be and how components would fit in, but the design is flawed in antweights because of the 50% drop-off rule; the ricochets from impacts would be uncontrollable therefore it would probably spend most of its time throwing itself out of the arena. It would really need a fully sealed arena to stand any chance of succeeding. Then again, I could just make it for fun
Ben: The last time I weighed it it was sitting at 60 grams but I've since swapped the battery for a smaller, lighter model. Plus that reading was taken from a rubbish pair of scales so I'm going to get a cheap little set of digital ones from Argos tomorrow that'll be handy for these robots as well as my beetleweight(s) and see what it's sitting at now.
but the design is flawed in antweights because of the 50% drop-off rule; the ricochets from impacts would be uncontrollable therefore it would probably spend most of its time throwing itself out of the arena. It would really need a fully sealed arena to stand any chance of succeeding. .
lol, just like mgm (antweight fbs with tuna can shell) and mgm2 (antweight overhead bar spinner) was alot of fun but got written off by militant :P
That drawing doesn't look too far away from Eric's shape but I see what you mean about the slight reduction in relative length, still looks close enough though . The 1.5mm aluminium armour will be thicker than big Erics though
Yeah, it's not that accurate but once it's all coloured up to match, you should be able to tell what it is
Not got off to the best of starts though, was hacking some old servos to use the boards as speed controllers but out of four, I currently only have one working one due to broken bits/overheated circuits/random failures on the rest, so I took the lazy way out and bought two 2A controllers off eBay
The mini Chaos 2 has been shelved for the upcoming AWS as I was having problems with both the drive and weapon. The drive wheels weren't touching the ground equally so it was struggling to steer in a straight line and then I buggered the weapon servo which just compounded a rather frustrating day yesterday.
So I decided to take all the parts I had for a fleaweight and throw them into an Electronize cover and add a polycarb wedge. Introducing:
Kiss My Asimov
Weighs in at 59g, so got 16g spare to devote to a little more armour. The wheels were external originally but that meant it couldn't fit in the 3 cube so I had to rip everything out and start over again. But it's a fun little beastie to drive
Progress on EricA is much slower. I've only got some of the chassis made and one wheel/motor combo attached. It looks quite odd and un-Eric-ish due to the size restriction. Eric's quite a bit longer than it is wide, but the ant is pretty square and has to be rather tall to fit everything in. Hopefully it'll bear a resemblance once it's all finished though:
I have to admit, these things take a lot more work than I anticipated, possibly because I'm not used to building at this scale. I could throw a basic featherweight together in a weekend but struggled to get a 150g creation made in the same time-frame. Oh well, gives me something to do with my evenings this week...
