Re: RogueTwo Robots
Lol, nope. That pic was taken back in March. Plans are under way for the rebuild but I can't really do any robot work until I start earning some dosh :P
I've not got round to dismantling Drumroll from the champs and haven't yet tried the motor to see the spin-up but I have had a good look at the unit and can follow what you said, with exception of the M4 bolt/washer part.
I know the titanium shaft is currently capable of just being pulled out of the gearbox, but I can't visualise the area that you're referring to for drilling and tapping a hole, or how it will hold the shaft in. When it's pressed in all the way, the rear of the ti shaft rests and rotates in the rear bearing so I was just planning on having something (small bit of plastic attached to the chassis) at the front of the gearbox/output of the shaft pressing against it just to restrict any movement and prevent the shaft from coming out. Or is that pretty much the same as what you were meaning?
Originally posted by calumco
) but as the designed progressed, it changed slightly and now boasts, at most, only minor similarities.
