Two beetleweights
  • Two beetleweights
    My sons are begging me everyday to go ahead with ordering all the parts but im unsure of a few details. If its not to much trouble i will like to ask a few questions that are probably rudimentary to all of you. Im building two beetleweights, a spinner and a wedge/lifter as per their research and drawings. So im buyng:
    Spinner bot:
    2 Kitbots 1000 RPM Gearmotors
    Sabertooth 2 x 5 RC Dual Motor Speed Controller
    Hobby king 2.4 6ch tx & rx v2
    NTM prop drive series 28-26a 1200kv/286w for spinner running a 4-5inch bar/blade
    Turnigy plush 30 amp esc for spinner motor
    Wedge/lifter bot:
    Im going to attempt to rig some hub and wheels along with the chassis and body. I need a recommendation on an appropriate cheap servo and esc for the lifter. And the right battery and charger to power both. I understand the the lifter will be running less amps than the spinner but i want to use the same set up as the spinner in case my son decides to change his lifter into a spinner. Any help is much appreciated. Thanks
    Firstly... Welcome! I remember bugging my father to do exactly the same when robot wars was on... sadly nothing ever got made beyond cardboard mock ups.
    All looks good, there is once change you can do to save a bit of money. We bulk buy our 1000RPM motors from china, given you get 2 for the price of 1 being shipped from the US anyway, and they are on ebay from several sellers: http://www.ebay.co.uk/itm/2-x-12V-DC...item4d02562621
    For the lifter you will need a servo, you plug it straight into the receiver (no ESC required) but that's not my domain so someone else will have to answer that.
    I would also suggest getting 10A ESC's from Botbitz in Australia: http://www.botbitz.com/index.php?rou...&product_id=56
    Most people use them, me included, and if you burn one out at an event its good to know someone will have spares. There is nothing wrong with the Sabertooth, buts its a lot of money and if it goes boom then you will be out.
    I have just bought that motor myself for a new spinner, I was going to go with direct drive for a drum but a 2:1 ratio on that bar should be suitable, you might even be able to take it up to 150mm/6" without much issue.
      I agree with the Botbitz 10A suggestion, I have both but I use the sabretooths in antweights only.
      I`m currently using two Botbitz each running three 1000rpm motors to make a very effective six wheel drive robot. (Limpet XS)
      Doon`t forget you`ll need batteries and the relevant charger.
