My sons are begging me everyday to go ahead with ordering all the parts but im unsure of a few details. If its not to much trouble i will like to ask a few questions that are probably rudimentary to all of you. Im building two beetleweights, a spinner and a wedge/lifter as per their research and drawings. So im buyng:
Spinner bot:
2 Kitbots 1000 RPM Gearmotors
Sabertooth 2 x 5 RC Dual Motor Speed Controller
Hobby king 2.4 6ch tx & rx v2
NTM prop drive series 28-26a 1200kv/286w for spinner running a 4-5inch bar/blade
Turnigy plush 30 amp esc for spinner motor
Wedge/lifter bot:
Im going to attempt to rig some hub and wheels along with the chassis and body. I need a recommendation on an appropriate cheap servo and esc for the lifter. And the right battery and charger to power both. I understand the the lifter will be running less amps than the spinner but i want to use the same set up as the spinner in case my son decides to change his lifter into a spinner. Any help is much appreciated. Thanks
Spinner bot:
Wedge/lifter bot:
