ok note to self dont copy anvil, i must admit my first bot aint gona be clever i just want it to work in the weight limit 1.5kg is not as much as i thought it was after doing some rough calculations as to what i think thinks are going to weigh in at
couple of questions
Originally posted by harry hills View PostAlex kinda bent/broke the rules with regards to the link lol
And this was all because I had no idea how the wiring would work and so I decided to work it out later. Anvil is now written off so don't worry about copying it.
ok noted wont be doing that i have been reading the rules and trying to make sence of a few bits im used to using lipos from airsofting but would the rules allow me to place the whole bot in a charging bag/box or di i have to be able to remove the bateries
ok this is helping much will these be enough to run a 6wheel brick??
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
TBH a beetle pusher can run for a long time on 1300mAh, as for voltage (how many cells), the motors Harry showed take 12v (3S) but can take 14.4 (4s) easily. General rule of thumb says they can run 1.5 times their stated voltage (which in this case is 18v (5S pack, near enough), but I can't guarantee how long they'd last. If speed and power is what you want, 4S will probably suffice.
