Originally posted by Flag Captured
View Post
Eggbeater
I could make a mini Conker 3 but it would look basically the same. Or should I do it anyway and we can duel it out?!Last edited by Eventorizon; 4 August 2014, 07:59.
Ellis finished everything. Being sent off tomorrow morning. Will be buying some round belting and should have some spin ups soonish.
Disc, pulley and hub for the unnamed vert.
Machined the bulkheads. Not overly happy about how they came out but they should hold. Loads of meat to pocket out tho.
Ellis's stuff and the disc arrived around midday today. Really lovely stuff.
shoved the disc in the bulkheads to get a feel of the thing. I'm now considering going much more nightmare style. Weight is looking good, 1182 for everything bar the HDPE/CF framing and armour.
Pulley and hub mounted to disc. Don't have any caphead M5 around so I just stuck countersunk bolts in for the time being. Bearings go in each side. Press fit into the pulley/hub.
I milled the slot in the pulley for eggbeater. The slot engages with the beater to drive it. No more setscrews there
Mounted in the robot. Spins nicely. Totally smooth, no wobble at all. Which with my tolerances/ghetto machining is a bloody miracle.
Also, I needed replacement hubs. Spinza, along with bending the mounts of the motors cracked the hub making it basically useless. Made this HDPE replacement.
With 4wd Eggbeater turns pretty nicely. With the beater full whack? Who knows.
Vert will probably not be able to turn. Spin up fast, go forwards and try and hit stuff.
And thanks guys. You all have nothing to worry about. My robots often suffer from stagefright :/
Considering naming the vert Damp Squib.
