Can belts be twited round 90 degrees? I mean so one pullys at a 90 degree angle to the other? Can timing belts do this, or would O-ring type belt be better? Thanks
Beetly belts
 Re: Beetly belts
 found picture and some more info
 Nasty weapon plus invertibility is a winning combination. The secret to making this work is custom extra wide & tapered cheeks on the motor pulley and a wider then usual weapon pulley. I think this would work just a well for grooved pulleys if you use the more flexible style belts.Attached Files
