    i wish i had a bw drum, love all drum spinners
      SLOTH bw put together just so all beetles not spinners,test vid link at bottom of pictures
      small test vid of drive
      http://s348.photobucket.com/albums/q329 ... 5e1cc3.mp4
        that's really cool! what's the armour?
          Daves vert isnt called Fetish, Its called RPM
            The armour is steel
              Originally posted by PJ-27
              All you need now is a bar spinner and a drum and you've got all bases covered!
              That's it, I'm making a BW Drumroll! Dunno why I'd never given it much thought before now, but got a fair few parts handy for it so will try and churn it out once Flatulence is up and running.
                  Do an event when I've not at uni and I'm there. Fancy my chances against all of them so far!
                    Talk about selective quoting
                    Ewan, you're a student. By definition, you're not at uni 90% of the time!
                      Mine is going to be NOT a spinner! Mine will be an axe, and quite a substantial axe if I can get the 900 relica on the weight limit.
                        I wish, should've done English or History of art!
                          Wow, that would be powerful! I did axe testing bolted straight to the shaft of about a 500 size motor, that went straight though a biscuit tin, and pretty far in to plastic.. If you pull it of David, it would pretty damn awsome!
                            Handy if you ever need to fight a biscuit tin.
                              I've now got all the parts for Carbide ( Mini Cobalt ) another non spinner
                                Custom heavy duty brushless shaft.
