Re: UK Kilobots - 1.362kg (3 lbs) Combat Robots
@ Jordan: I've taken apart varios disk drives, the motors in them are really nothing special. I could only open one because my dad realised (after I asked him if he was sure) that one of them worked fine, just old as all. The one I opened had 3 motors, one for the tray, one for spinning up the disk, and another which I can't remember what it did, but it was identical to the one powering the tray.
The two identical ones are actually pretty powerful for their size, I'll have to find out howmany volts they're designed to run at, they're a possibility. If not I'll add 'em to the stash of god knows howmany old and new and bodged motors I've collected over the past few years.
Sadly, the motor that drives the actual disk is a stepper motor, as you say. Masses of wires, I would hack apart the bit of circuit board that the wires were attatched to but the bit I need is right in the middle, so, that's a no go.
I have around 60 spare euros hanging around, so I'll go and buy some fresh motors. Old RC model motors are a little simple and... the same now days.
