Re: UK Kilobots - 1.362kg (3 lbs) Combat Robots
That's excellent Andy. Supplied data is one thing but it doesn't beat real results from real testing. Anything more you learn about that model of servo would be welcomed
I'm definitely not expecting fast-flip speeds, but as you say, with a suitable ratio I can hopefully get something reasonably effective. For a first kilobot it will certainly be a learning experience!
Ewan, the lack of metal gears caught my eye too and it is something that I will be monitoring. Once it's all built I think several test flips will be in order to see how the gears stand up. If they aren't up to the task, I think there are less powerful servos (still in the region of 12kg/cm) on the Giant Cod site that have metal gearing, so that's a back-up for the moment.
Just want to say too, although I've not built much so far, what I have done has taken less than an hour of construction time. I thoroughly enjoy featherweights but it's nice building something smaller that doesn't require as much 'heavy-handed' tooling (for lack of a better description). Whether the construction is strong enough to stand up to some of the brushless spinners that are being designed/built remains to be seen
