    Some won cut the a arial of my robot so it don't work
      ...There are new build rules for 2012?
      And that sucks Pugster, i'm sure you'll fix it, though.
        I can completely understand the need of a link, from what I've seen there is done seriously powerful robots out there (like 180 and , or how ever it's spelt,) and with such short spin up times and the fact Id have though it could go straight though flesh and bone, I wouldn't go to an event with out every one having links. Even Rambots could drive of a table and break someone's foot.
          Bws were written into the 2011 build rules, and it does not say that bw require links. IMO the need for all robots to have a link is ridiculous due to the Low power of the majority of beetle weights. They're a tenth of the weight of featherweights, it would have to be a pretty powerful Rambot to be able to break your foot. As regards to spinners having links that's a whole different matter.
            Originally posted by jonny
            The requirement of a link on a 3lb robot seems pretty stupid to me.
            I disagree. As long as the measure is not incredibly over the top, then nothing's stupid when it comes to dealing with safety. Not just for spinners either. My BW servo-flipper has the battery pack under the lifting arm and if I was to power up the robot just by plugging the battery pack in, I would have to lift the flipper arm. This means that the flipper could potentially close in on my fingers when I power up, and considering the servo has 20kg/cm torque, it wouldn't be a painless experience.
            Having done a spin-up test with the spinner I half-made, I wouldn't want to have to reach in and try to unplug a fiddly battery connection if for some reason it went out of control. Much quicker to grab and pull a link that isn't in the line of finger-slicing.
            Although the beetle class was added to the rules, I'm not sure if the link and power light sections were updated to accommodate beetleweights. But as far as I'm concerned, links, power lights and failsafes are a requirement, as per the first post in this thread.
              Making a link/power light a universal requirement would put off newcomers who (like pugster) who have just got an rc car and shoved some armour on. For scenarios such as batteries under flippers etc the choice to have an easily accessible link/switch should be that of the builders.
                Got to agree with the original post too. For all the effort it takes to add a link/power light to the robot and the safety improvements associated with them I would say its very important, to be honest, I fitted mine before I was even aware that it isn't in the official rules just out of good practice. Bear in mind that as/if this class progresses these machines are only going to get stronger.
                  Not sure if putting off newcomers is really a worthy reason to forget safety. Imagine if that logic were applied to racing cars, we don't use fire protection suits - they're uncomfortable and stop people from coming.
                  OK maybe that's a little extreme but the logic is along the same lines.
                  I haven't built a beetleweight but it doesn't take a genius to see that something like 180 could be extremely dangerous.
                    to stick with your car analogy you don't wear a fire protection suit when you're nipping down to the co op in your renault clio. but say if you're going to the co op in a vehicle that is essentially a gas tank with a large engine attached driving at excessive speeds you would use a fire safety suit.
                      Then a line must be drawn. When is something safe, when is something not? That's the difficult part. It's either decide individually which robot is deemed dangerous (if BWs became very popular then this would be impractical), make all of them require safety components, or make it OK not to have any at all. Seems safer (lol) to make all of them require safety equipment, doesn't it?
                        +1 for link
                          featherweights don't have a set rules for them all, for example pneumatic systems require to be able to be locked. requiring all beetles to require a link and powerlight is like requiring all featherweights to have a locking bar even if they have to pneumatic system. beetleweights wouldn't have to be judged individually they'd just fall into certain categories. For example, if the beetleweight in question is/has:
                          a spinning weapon
                          lipo's
                          a pneumatic system
                          accessing the battery involves contact with the weapon (ie jamies bot)
                          if the beetleweight had any of the above then a removable link would be a requirement.
                            Safety is always important, considering a link on a beetle could probably been something like a deans connector it doesn't ahve to weigh that much or really weaken the armor by putting it in, its not that big of a sacrifice mounting one.
                              Well I still think they should be needed for every one, because I don't want the corner of a 3lb robot falling of the table and landing on my foot, I think it should be needed in all robots unless there a special case like a rc car, but it still wouldn't be to hard to wire one in, even if someone has to do it at the event for them, I just think that it will make every thing safer, as it would be hard to draw the line, like I wouldn't want a razor sharp axe slicing over my arm, etc
                                it is just so hard to add a removeable link to an rc car
