    22g? So the product description is only just over Twice as heavy as it should be!
    Do you use them in your ants Dave?
    I hope they're good, £50 is quite a sting!
      yep, mine was well worth it untlil i blew it up
        does anyone know a good website to get brushless motors suitable for a spinning drum?
          PJ: I use them in Bulletproof and Kill-a-chav and I have helped to make several other robots that use them and no complaints thus far. In fact I beleive Jonno uses them to power the 5KG Battle Ratz
          Push-n-shove: Try Micron RC, they have quite a few good brushlesses.
            Ok thanks, I'll have a look
              I dunno about suitable, but I'm giving this website a good search;
              http://www.hobbyking.com/hobbyking/store/index.rc
              Is it the Australian forum that already has a well established Beetleweight category?
                http://www.micronradiocontrol.co.uk/ba_esc.html
                Do you reckon the 30a would be up to much?
                  Those are uni-directional controllers
                    I think the weight they show on Technobots is the packed weight, so that might include a fair few pieces of packing foam, or plastic bags or whatever. But a weight saving of more than 50% is no bad thing
                    And for the (almost) £50 cost you'd be as well spending £3 more and getting the 12A Sabretooth if size and weight isn't an issue. Definitely suitable for a beetleweight and probably usable in a 2WD drill featherweight if you ever need to swap parts around:
                    http://www.technobotsonline.com/saberto ... or-rc.html
                      Hopefully it is the same with my motors and wheels. I realised it says they weigh 160g each and the wheels 140g each. Bit too heavy.
                        Hang on, wait, what parts are you using?!
                        My wheels weigh 13g each and motors about 72g
                          my wheels weigh 100g together and the motors are about 70g
                          • Re: UK Kilobots - 1kg Combat Robots
                            Originally posted by widow_twanky
                            These work quite well, have a metal spur gear box and are cheap as chips. Speed is respectable on an 11.1V lipo but could do with a bit more oomph!! so a higher voltage would be good. Run time on a 300mAh lipo is half an hour or more.
                            Andy
                            http://robokitsworld.com/index.php?main ... ucts_id=50
                            http://robokitsworld.com/index.php?main ... cts_id=171
                            http://robokitsworld.com/index.php?main ... cts_id=204
                            Using these.
                              @Jamie
                              Oh yeah! How come the 12a one is cheaper than the 10a and marginally more expensive than the 5a? It's lighter than the 10a too.
                                It seems a bit weird but the only thing I can think is that the 12A model is superseding the 10A model so perhaps it now costs less to make the controllers than it did a few years back when the 10A one first came into production, and they've found lighter ways of making them? Who knows
