Designs
  • Designs
    PLEASE! help me think up some
    flipper designs using a servo
    thanks
    Designs
    u can make a lifter with a servo not a flipper
    be more specific please
      Designs
      http://www.teambeligerant.cjb.netwww.teambeligerant.cjb.net - go to useful technical information, then click on Flippers. Hopefully this will be of some help.
        Designs
        thanks,
        I appreciate your help Gary
        Jono
          Designs
          Actually you can make a flipper from a servo. I have never finised a complete Ant but I did have the flipper mechanism working. Basically the servo acted like a lifter but the arm was sprung loaded and was held in place by a catch. The servo would try to lift the arm which bent the spring against the catch until the pressure finally overcame the catch and the arm shot up. It actually started as an axe which worked well on the bench but when put into an Ant chassis the ant performed a back flip every time the axe was fired.
            Designs
            Is there anyone who has seen the Swedish robot EntrAnt?
              Designs
              yep seen it fought it and beat it, but its a damn good robot quick with a superb flipper
                Designs
                yeh thats got a superb servo flipper
                heard lots about that
                  Designs
                  could someone please enlighten me a bit more about Entrant as ive never heard of this bot
                  Thankyou
                    Designs
                    Craig, that was the old EntrAnt and it was nothing like the new improve one.
                    Jono, they have a website, but thats mostly in Swedish.
                    http://www.bovik.homeip.net/robot/default.htmhttp://www.bovik.homeip.net/robot/default.htm
                      Designs
                      Entrant is fantastic stunning electronics inside glad you guys got best engineered at AWS13 for vacuum that was fairly impressive, future champs
                        Designs
                        Yeah.....to bad that that he lost vs Resurrected...if they had a roof on the robot they could have wone the competion.....
                          Designs
                          Ehm, Craig, I got the award for best technical engineering, Vacuum was awarded with the most original design.
                            Designs
                            Gary, I looked att your tech page, but I dont get how I should mount all the things on the flipper arm...
                            And is glassfiber god as amour?
                              Designs
                              Hi Joacim
                              The flipper arm is yellow, the servo arm is green. The flipper is hinged to the robots body at point D.
                              The linkage between the servo and flipper (red) must be free to move at both ends. The linkage could be piano wire or a recycled paper clip, with a bend in the end so it fits in a hole in the flipper.
                              Unfortunately I dont have any pictures of the linkage on R.O.N.N.Y or RampAnt. If I ever figure out how to take a good picture of the linkage (its hard to see when the robot is complete) I will add some to my site.
                              Glassfibre is certainly light and is fairly strong, but its main benefit is that it can be moulded. If you can make a shape that will deflect the impact from spinners then you may have an advantage. Carbon fibre is lighter and has been used to good effect. Kevlar hasnt been tried yet AFAIK...
