Antweight Database
  • #91
    Antweight Database
    Looks really good Craig!
    Anyway, here is my ant
    Name- Ant Awe
    Weight- currently 144g
    Drive- 2x 30:1 motors
    Speedo- Barrello
    Battery- 6v Ni-Mh
    Weapon- Flipper powered by HPXF servo
    Armour- 0.5mm Aluminium
    Its a mini version of Iron Awe!!
    Pic on profile
    • #92
      Antweight Database
      a barrello ? its a sabretooth you use isnt it ?
      • #93
        Antweight Database
        I love Ant-Awe!
        • #94
          Antweight Database
          Thanks Matt!
          It used to have a sabretooth in there but Alex from team Blitz now has it in his ant.
          I plan to use the 3rd channel on the barrello for the next Ant Awe.
          • #95
            Antweight Database
            I thought the 3rd channel was 1 way only ?
            • #96
              Antweight Database
              It is- I have plans :wink:
              • #97
                Antweight Database
                pneumatics then
                • #98
                  Re: Antweight Database
                  Since I was bored after doing revision i decided to take frostbite apart and rebuild it since it never worked properly so I took it apart and turned it into a fleaweight.
                  Weight: 68grams
                  Length:7cm
                  Width: 6cm
                  Height: 4cm
                  Armour: 1mm HDPE
                  Weapon: 0.5mm Alumiunium lifter powered by a micro servo
                  Drive: 2x modded spektrum servos
                  battery: 6v 120mAh Ni-Mh
                  notes: currently a bit slow- will try speed modding the servos this weekend
                  Pic:[attachment=0:30rt4hiu]frostbite II.JPG[/attachment:30rt4hiu]
                  • #99
                    Hmmm....duct tape armour.. wonder how long it will hold
                    • Re: Antweight Database
                      this is what I do when i'm bored :P
                      K4t (a.k.a. Katjusha 4, a.k.a Kat)
                      Drive: 1:25 6mm planetary gearmotors
                      power: 1 cell, 3.7v 70mah LiPo
                      locomotion: 2x wheels
                      armor: 0.3mm CF
                      speedo: servoboard
                      weapon: Brushless Spinner at 35 krpm
                      weight: 19.5gr
                      r.x Penta 5
                      t.x Hitec Flash
                      notes: DUDEWEIGHT!!
                        Originally posted by daleksupreme7
                        hi who knows how to make a servo spin 360 can you help me if you do know
                        send an email 2 extermante@msn.com
                        That all depend on the servo you are using. Which brand and model is it?
                          Rick Maas from Team RCC has built a new Antweight:
                          Photographs:
                          Specifications:
                          Weapon:
                          Axe / Lifter / Pusher
                          Axe powered by GWS Park HPX servo @ 5V DC
                          Armour:
                          3mm HDPE shell
                          1mm ALU baseplate
                          Drive:
                          2x 12mm Inline Gearmotor, 443 RPM @ 3V DC (Sanyo clone)
                          Speedcontroller:
                          Barello ant 100
                          Receiver:
                          BR6000 2.4 Ghz
                          Battery:
                          3x Atomic Workshop 130mAh Lipo
                          Dimensions:
                          100x85x100 (LxBxH)
                          Weight:
                          149,8 Gram
                            Such an awesome looking machine, kudos to Rick
                            Will: Do you still have the crushing claw and big servo that came with Frostbite originally ?
                              Black Knight looks brilliant- can't wait to see it running!
                              Still got the claw and servo- hasn't been used in a while but still got it.
                              While I remember here is my latest antweight- Ant Awe 6!
                              Name: Ant Awe 6
                              Weight: 135g (plenty of weight for some extra armour)
                              Length: 11cm
                              Width: 11cm
                              Height: 7.5cm
                              Armour: 0.5mm Aluminium Armour, 2mm HDPE base
                              Weapon: Flipper powered by HPXF parkflyer servo
                              Drive: 2x 30:1 micro geared motors
                              Controller: Peter Waller's Option D controller
                              Battery: 7.4v, 180mAh LiPo
                              Rx: Spektrum AR500e
                              Notes: Its a mini version of Iron Awe 6!
                              Photo (still needs painting)
                              http://s881.photobucket.com/albums/ac13 ... g&newest=1
                              Photo with Ant Awe 5
                                Some of you may have noticed that Ant Awe 5 has been looking a bit tired and worn out over the last few events so I decided to give it a much needed rebuild.
                                It now features a new chassis with removeable shell (as on Ant Awe 6). This has made it much easier to work on and the drive and flipper now work a lot better.
                                Here are some pics (it still needs another coat of paint and the stickers added)
                                http://s881.photobucket.com/albums/ac13 ... 20Awe%205/
                                The stats are pretty much the same as before
                                Weight: 148g
                                Length: 11cm
                                Width:11cm
                                Height: 7.5cm
                                Controller: Barello ant 150 controller
                                Rx: Spektrum AR500e
