Hi fellow roboteers i was just wondering is there a catagory between 150g and 1kg and also if i have a robot that only uses simple components eg 2 motors, 2 servos the reciever and 4 aas does it still have to have the different cut off circuits and remote links etc if it does get to a kilo?
Any weight catagories between ant and feather?
it may have to be a feather weight then darn i was hoping to get away without putting all that extra stuff in my robot it dosent have any speed controlers or weapon systems or anything like that so where would i put the link etc?
Alex, from what Ive seen in your posts, it seems the best robot for you to build would be a 150g antweight. Anything larger than this needs more than a Mechano set to build it. If you are planning something bigger than this, a few basic tools can build a featherweight. There arent many (if any) lightweights around these days anf they are more expensive and harder to build that a featherweight. However if you are going to build a FW - go for the maximum 12kg weight limit instead of the minimum 1kg one. Personally Id suggest building an AW or a full 12kg FW.
Hope that helps in some way.
my components are too heavy for an ant and it would be expensive to get all new bits but i am going to keep building and i will start out light but i am sure once i have put everything else in it will be a lot heavier. build time is not in surplus amounts as i am still at school however i now have the basic design in my head the wheels are finished just got to cut everything out of MDF put some armour on test it fill it with more MDF then have it as an ornament maybe when i am at uni i will have it completed.
