if its X-terminator vs Typhoon, i think Typhoon will win because X-terminator never moves at the start till its blade is spun up and seeing how quickly typhoon spun up their blade and killed off atomic, ill say Typhoon in the final as well as Storm II
Its gonna be a classic, but heres what I think will happen (assuming the draw goes like this):
Tornado vs. X-Terminator
Tornado will use a wedge weapon to protect from the spinner, and will easily outmanoevre X-Terminator (despite the defensive tactics of XT), get under it and push it around and eventually down the pit.
Storm II vs. Typhoon
Typhoon will spin up to speed, but Storm II is the best in the business when it comes to armour, and will resist the blows and send Typhoon flying with each hit, and Typhoon will either get broken or tipped over.
Tornado vs. Storm II
A dream encounter, one which could go either way - Storm II has more speed, power and better weapons/armour, however Tornado is more agile and better driven, plus it does have a small amount of ground holding at the back. Both have similar tactics, but I think Tornado will try and use the pit more than Storm II. But there is a small chance that Storm II could send Tornado OOTA, so its anyones guess really. It could well go to the judges, but if I had to put money on it, Id go for my original prediction at the start of the 7th war - Storm II.
