Predictions
  • #31
    Predictions
    Oh, and Matty, Im like that too. I feel I have to return the favour.
    • #32
      Predictions
      I doubt that X-Terminator will be able to damage TAN at all. However, they have two LEM130 for drive.
      • #33
        Predictions
        Dont underestimate the disc of XT. It is exceptionally powerful. Also remember that if it doesnt pierce it can always hit hard enough to flip TAN or damage those elctronics.
        • #34
          Predictions
          I definately think TAN will beat Bulldog, you cant blast people for their opinion, TAN has proved its a very well controlled hard to beat robot, Bulldog has yet to flip someone OOTA, and you cant have a chance in the pit, did you see how easily it dispatched gravity and everyone else in its heat
          • #35
            Predictions
            I doubt anyone will believe it, but after the robochicken fight, one of the speedos in TAN was down.One of the chips on the board came out of the socket.
            Bugs remedied that very nicely by soldering the thing in the socket.And the second one for good messure.
            So yes, if the wacks are hard enough, the electronics can fail.
            • #36
              Predictions
              Jamie, did you not see the Tag Team Terror? Bulldog flipped Pussycat clean out of the ring and it wasnt even close to the wall! Are you blind or something? (No offence, but I dont believe what you are saying)
              • #37
                Predictions
                Yes, I saw the Tag Team Terror as well. One moment Bulldog had its flipper underneath Pussycat, NOWHERE NEAR the wall, the next second Bulldogs flipper was coming up, the next Pussycat was soaring through the air, the next, Pussycat was OUTSIDE THE ARENA.
                • #38
                  Predictions
                  I saw that Tag Team Terror bout from in the audience. It was a completely genuine and very well executed OOTA.
                  • #39
                    Predictions
                    OK, well I accept that but Im still not going to change my predictions.
                    • #40
                      Predictions
                      Yes, Have you seen Tough As Nails dispose Scraptosaur and Disco Inferno within seconds of the battle starting,there have been much more OOTAs than any other series by far, but Bulldog breed seemed to not be able to get it other the wall same thing with Thermy, Bulldog may be able to flip TAN,but bearing a fluke like Iron Awe TAN is too controlled to be tossed around
                      • #41
                        Predictions
                        Good God! Soeone I agree with! Honest to God, agree!
                        • #42
                          Predictions
                          you no what TAN has a chance because the tatic is grab em push the pit button and drop em in. if that works then they will go through
                          but bulldog bread will need to fast
                          • #43
                            Predictions
                            Bulldog Bread? What new robot is this? :P
                            Anyway, perhaps youve noticed, most of the shapes TAN has had to grab - Panic Attack and Disc-O-Inferno, for a start - are pretty low-profile? Bulldog Breed is a much bigger shape, so TAN will have to get at the right angle.
                            • #44
                              Predictions
                              i doubt Jeroen is looking for a specific angle, grab and squeeze is his only tactic. The thing with TAN is dat its centre of gravity is very weird. flippers usually cant get it OOTA. they can flip it lots of times, but the robot usually just flips over instead of going up and over.
                              It can be done, but you need a right angle and a very good flipper to do it.
                              • #45
                                Predictions
                                Hmm... If someone could stack it against a wall, then quickly come in and flip again before it got down, theyd probably do it.
                                I think the dog will win, but remember it has nice flat sides for TAN to grab hold of:wink:
