Beetle pulley
  • Beetle pulley
    Hey all,
    In need of a new weapon pulley for Lynx seeing as it duffed the old one, can't seem to find any online that suit my needs. Any help would be great.
    Cheers
    What sort of thing are you after? I've been using printed pulleys on both my beetle spinners and they seem to work fine. The ones on Soundwave are 18 months old and are still in use.
      Needs to be 50mm diameter with an 18mm bore, belts I'm using are just the generic 3mm o ring stuff.
        I can do that. What holes do you need for mounting?
          4 m5, 10mm from the outside edge of the bore. Cheers Will
            If not I can turn an aluminum one.
