FW basic setup
  • FW basic setup
    I'm looking to get into this game, and have designs on a HW bot.
    But before that can happen I need to play in the FW arena and test some of my ideas.
    If you possess a FW platform without frills, that's what I'm looking-for. Make me an offer.
    ​Jasper
    www.scot-bots.co.uk/shop
      You could knock something up quite easily
        Wow. The 4WD Scot bot looks uncannily like the Kaizer I bought off Jamie.
          Probably quite similar, but then most 4WD ram bots probably are. It's a bit bigger than Kaizer, using 124mm wheels and bigger batteries and no lifter so quite different inside.
            Tony, just Taller & without the front wedge as far as I can see it. The batteries are about the same volume due to them being 2*6V SLAs, the electronizes were laid out like that too for the 2010 champs.
            More importantly,it's the front panel that reminds me. The underlap behind the front panel. I pulled that forward in the currentdesign to support the front wedge.
            I must have a go at a 4WD one day.
              Ahh I see, didn't know it ran SLAs.
              Hopefully the 4WD versions run just as well as the 2WD ones but with a bit more power behind them
