Feather flipper bits
  • Feather flipper bits
    There is a similar thread below with no responses. So failing that, some links for new parts would be useful. I need everything!
    Re: Feather flipper bits
    This is what I'm using:
    2/5way valve (Qty 1)
    http://www.ebay.co.uk/itm/DC-12V-2-Posi ... 53f148c741
    Quick exhaust valve (Qty 1)
    http://www.ebay.co.uk/itm/1-2-Inch-Bsp- ... 19cf7e759a
    Pressure relief (safety) valve (Qty1)
    http://www.ebay.co.uk/itm/Safety-Valve- ... 19d2f3e58e
    Regulator 150psi (Qty1)
    http://www.ebay.co.uk/itm/NEW-PAINTBALL ... 2a1dff3251
    On/Off valve and adptors (Qty1)
    http://www.ebay.co.uk/itm/Paintball-air ... 27ca0a11f9
    High pressure line (Qty1)
    http://www.ebay.co.uk/itm/Paintball-Sta ... 27cf6e2f20
    Paintball tank (Qty 3)
    http://www.ebay.co.uk/itm/PaintNoMore-P ... 337857e173
    Look here: viewtopic.php?f=240&t=5294 to see how I set the system up. Of course you will need various pneumatic fittings and a pneumatic cylinder.
    My cylinder is based on this one:
    My cylinder is ba
      Thanks bud, as an avid paintballer I have most of these bits already, just had not thought of using them. Any other places I might get a cylinder?
        There are loads of cylinders on ebay, if you're going for a low pressure system almost all are suitable, a 63mm bore would be ideal for use with a 12oz tank. The only problem with them is the port size, its too small - that's the reason I cannibalized the cylinder for parts and manufactured my own. It's pretty straight forward though if you have access to a lathe - I won't tell you I'd do it for you because I'm too far away, but I'm sure you'll find someone nearer who'd do it for you!
        Found out Paintball stuff is really great - parts are compact and not overly priced. Btw, make sure the regulator you use is a low pressure one like the one I linked - you'd make a balloon of the cylinder if not
          http://www.ebay.co.uk/itm/Pneumatic-2-3 ... 43b6e3d606
          What do you think?
            That's good, but I'd blank off those ports and drill one at the bottom end to fit a 1/2 fitting, the original ones are way too small - but otherwise a good find
