10mm id steel tube.
  • 10mm id steel tube.
    Hi
    I need a peice of steel tube 10mm id, 100mm long, 2 or 3 mm wall.
    anybody got an offcut.
    DaveMac
    Re: 10mm id steel tube.
    Got something with outer diameter 12. Hydraulic tubing.
      Hi Maddox,
      Really need 2 to 3 mm wall, but thanks anyway.
      DaveMac.
        We have various sizes of pipe at work with various wall thickness will have check the charts to see which size and schedule, probably something like 1/4 schd 40 might do the job, if we don't have it in steel we will have some in st/stl
          Hi Abam
          Steel would be great, will need to be able to Mig it to a Plate.
          daveMac.
            Ill check tomorrow when im back in work, can weld st/stl to steel if you use st/stl welding consumables, ill check with the steel first
              Sorry just got round to checking, we've only got suitable tube in stainless steel
                Thanks for looking, I only have access to a Mig welder with steel wire and CO2 as gas, so SS is out.
                Many Thanks,
                DaveMac
                  For our purposes, it perfectly possible to weld stainless to steel with MIG.
                  The weld won't be as strong as the mother materials, bu¨t survivable.
                    think i found what our after
                    http://www.ebay.co.uk/itm/16MM-OD-X-10M ... 645&_uhb=1
                      Looks ideal, only problem is I only need about 100mm, probably nearer 80mm.
                      DaveMac
                        Hi there, new to the forum.
                        I was looking for something simmilar, but what I need is more in the region of 10mm id x 25mm od 300mm long. The 10mm id is the important part. The od isnt that important, but the closer the better.
                        Anyone have that in offcut or a link where it can be found?
                        Thanks in advance!
                          http://www.ebay.co.uk/itm/16MM-OD-X-10M ... 337c35d645
                          nearest i can find on ebay
                            Thanks yeah, I found that one too. That will be my last resort
