cheap speed controller
  • cheap speed controller
    i am starting a new project and would like either a scorpion XL or a sabertooth 12v or 5 amp speed controller quite cheap as i have a low budget.
    Re: cheap speed controller
    a scorpion xl and a simple cheap 5amp controller are at 2 ends of the scale in terms of spec, performance and price....what are you building?
      a featherweight. driller
        bad design, drills arent good weapons
          i got a really high quality motor to power it plus a strong material to make it out of.
            i would personally avoid using a drill as a weapon......just have a think about the process of drilling a hole
            holding the materail (clamping) is key otherwise the material will move and the drill wont make a hole
            your target materail will often be moving, sloped and quite often these days hardox which drilling normally is very hard
            if you want a damage bot make a crusher or axe bot can be done simple but very fun and effective
              i am stuck as to what to make then as this is my first project and i am new to this stuff.
                do like a rammer or basic electric lifter
                  which one inflicts more damage?
                    rammer i spose
                      but on a low budget with drill it will still be awful
                      build a barnslybot
                        i am not sure i just want a simple but effectrive robot and i should have some income soon so what would you recomend?
                          for about 200 quid you could build a basic featherweight, if you want a little damage then a thwack bot is best for you, its where you have an axe or hammer on the end of your robot so that when your robot turns on the spot people may get hit by the axe
                            2WD rambot is cheapest and easiest to do. Best starting there. Could maybe even do it for slightly less than Harry mentioned if you ask for the bits on here and use the cheapest possible parts.
                              if you get second hand parts i pretty sure you can make a simple 2wd rammer for about £90 ish
