Small piece of steel.
  • Small piece of steel.
    I need a piece of 80x80x3mm steel so I can make a mounting bracket for my ripoff speed 900.
    I know steel isn't all that expensive but wondered if anyone had an off cut since the bit I need is so small!
    Cheers!
    Re: Small piece of steel.
    Closest I've got is a piece roughly 100x100 of 5mm steel. Any use?
      Beggers can't be choosers! That would be great Jamie.
      PM how much you want for p&p etc....
        No problemo, I'll hunt it out tonight and see what it weighs. P&P shouldn't be too much, but cost of the metal itself is £50. That alright? :wink:
          Sounds reasonable
            Yeh sounds good just gimme your PayPal addy I'll send it right over. One slight problem, it's in my Nigerian bank account so I'll just need £10 from you to cover admin etc and I'll return £60. Sound alright?
              Oh yeah, I think your Uncle Omagahuwe contacted me about that earlier. All my account details are in his hands. He said he'd send me £25,000,000 as well for my trouble. WIN!
              Anyway, just measured the steel and it's 110mm square aside from one section where it narrows to 75mm. Not sure if that's a problem since you mentioned 80mm in your original post:
              [attachment=0:x8dhwqbd]DSCN6506.JPG[/attachment:x8dhwqbd]
              If it's suitable, I'll get it posted within the next day or two. Postage again is only a couple of quid so another drink at the NEC will be fine :wink:
              P.S. There are small splashes of concrete stuck to the underside of it (the steel is from a turbine base fixings template) but nothing a quick run over with a grinding disc won't fix.
                Good old'Omagahuwe an honest man....
                Looks Perfect, nothing an angle grinder won't sort out. I'll add it to your tab
                  Also is that a snare mouse mat?
