Trev reg and 600g co2 tank
  • Trev reg and 600g co2 tank
    Evening all,
    As titled, looking for the trev reg and one of those 600g tanks that John was selling before that the reg bolts straight onto.
    Cheers
    Dan
    Re: Trev reg and 600g co2 tank
    Funny, I can make the Trev mount on any commercialy available pressurized gas storage bottle.
    And I have handled a 20 oz bottle with normal valve now, that's heavy...
    I stay with my standard paintball bottle with on/off valve.
      I've got a paintball tank with an on/off valve but from what I've read, fitting a trev reg to a paintball tank requires some machining (I think) which i haven't got the tools for.
        Or a whole LP featherweight pneumatic system if anyone has one they are willing to part with
          Actualy, it doesn't . Replace the CO2 nut on the Trevor with a 1/2 bsp treaded nut.
            interesting, don't suppose you'd have a link to such an item would you?
              Never had to search for such an 1/2 nut, I make that myself. Takes about 30 minutes, including cleaning up the lathe.
              But you could try a place where they make hydraulic hoses.
              (also, my suppliers won't do much good for you, Belgium ain't around the corner)
                hmm interesting, i think i found something on google which may work. ill post it when i can find it again.
                Now i just have to find the reg!
                thanks for your help!
                  How about this?
                  http://www.gasproducts.co.uk/acatalog/1 ... Bush_.html
                    Nope, you need something else.
                    1/2 BSP female to 3/8 bsp male
                      http://www.supremeplumb.com/cgi-bin/DMd ... item=01053
                      and
                      http://www.chandleryworld.co.uk/catalog ... -1898.html
                      4th from the bottom
                      still looking for that trev reg as well!
                        That's both useable.
                        Unless the top one has conical ends.(very probably)
                          http://www.ebay.co.uk/itm/270720473558? ... 3D1&_rdc=1
                          How about this for a reg? To directly connect to the paintball tank. I'd change the outlet for something bigger
                            Looks like a cheap solution.
                            There is no use in changing the outlet. The reg can't deliver more flow , wasn't ment for it. That is why there are buffertanks.
