Technical data of the HBM 150 kilogrammes Verrijdbarework/Heftafel:
Maximum capacity: 150 kilogrammes.
Dimensions of the hefplatform: 700x450x35 mm.
Minimum altitude: 255 mm.
Maximum altitude: 740 mm.
Diameter of the wheels: 100 mm. Own weight: Approximately 44 kilogrammes.
Provided with 2 zwenkwielen including brake.
Packing dimensions: 82x48x26,5 cm.
Very robust implementation!!
with my own refinement.
Technical data of the HBM 150 kilogram work/lift table:
Maximum capacity: 150 kilogram.
Dimensions of the hydraulic lifting table: 700x450x35 mm.
Lowest position 255mm.
Max height: 740 mm.
Wheel diameter: 100 mm.
Own weight: Approximately 44 kilogram.
Provided with 2 brake swivel wheels.
Very solid build.
On another note, we have the 300 kg version, and we changed the el cheapo Chink wheels to 125mm Priory castor wheels. Still very happy about it.
