Aluminium sheet
  • Aluminium sheet
    need a piece 70cm x 80cm, 5 or 6 mm, good grade for hw chassis, cheap as poss in these hard times :wink:
    (Message edited by ady on February 19, 2009)
    Aluminium sheet
    now sorted
      Aluminium sheet
      Hi adrian
      I too am lookin for a plate of ally 6mm / 8mm for a heavy base plate....prices i have been quoted are crazy....can ya give me some pointers ??
      Cheers Froggy
        Aluminium sheet
        Hi Tony,
        i have just had a price which im not sure if it is cheap or expensive lol, its from a company up the road from me called shropshire aluminium, they have quoted me
        6082T6 is £69.00 or in a softer grade 1050 £49.00
        that is for 5mm 70cm x 80cm. is this the going rate? and im not sure if the grade is good enough.
          Aluminium sheet
          Adrian,
          Not a bad price, maybe slightly on the expensive side. Personally, I would offer them £60 as they are still making a a reasonable margin as I happen to know the wholesaler rate. Someone may know where to get it even cheaper of course, all depends on how hungry the supplier is.
            Aluminium sheet
            I should have also said that 6082T6 is about 3 times harder and has nearly three time the tensile strength of 1050H14 making it great for a stiff chassis.
              Aluminium sheet
              ok, cheers paul.
                Aluminium sheet
                get 8mm - beast has took so much abuse from thz and thor and its not even that damaged
                tough stuff - beats hardox :P
