20mm ROUND BAR
  • 20mm ROUND BAR
    Hi Everyone
    I am in need of a piece of round 20mm dia bar either ti stainless or silver steel ..... 450mm long ....
    preff ti ...
    anyone can you help please :
    (Message edited by botmad on August 24, 200
    20mm ROUND BAR
    ok so nobody i repeat NOBODY can help :sad::sad::sad::sad:
    ok thanks
      20mm ROUND BAR
      i can get u that but no ti
      ili let u know tom night ok
        20mm ROUND BAR
        Hi Pete,
        Sorry, didnt spot the original post.
        I have a piece of tool steel around 460mm long, 20.6mm dia. The material I used for the spike on KHz axe. Ill see if I can find out the exact material.
        Though I think youd be better off with a 30mm dia 2014 bar. Stronger than any and lighter than the steel bars.
          20mm ROUND BAR
          OK, its BS1 tool steel. Very strong if you get it heat treated. It comes annelaed.
            20mm ROUND BAR
            its only for the flipper pivot and goes through 4 x 20mm bearings so needs to be 20 mm john i can get the 0.6 turned off i think are you going to portsmouth ?????
              20mm ROUND BAR
              http://www.cromwell.co.uk/CTL4325413Thttp://www.cromwell.co.uk/CTL4325413T
              Long enough to get two from.
                20mm ROUND BAR
                No I think were going to be flat out building beta, so wont be able to make Portsmouth.
