Hi Everybody
I have a quick query regarding one of the build rules, specifically 6.3, which says that "current must not be carried through exposed components". My robot has a lifting arm which, when open, exposes a gap which the actuator passes through to move the arm. This leaves the actuator & some of the wiring it is connected to accessible, which I think might violate this rule. Could someone please confirm whether or not this is the case and if so, have any suggestions as to what I can do to fix this?
Thanks in advance.
Edit. Here is a quick image. If you need any more info, I'd be more than happy to provide it.
Thanks in advance.
