Certification of Full Pressure Ram
  • Certification of Full Pressure Ram
    The rules say,
    "Custom made components, or parts operating above the suppliers maximum working pressure, must beindependently tested and certified at 120% of the maximum system pressure available at that point."
    Please can someone tell me of a person/organisation who can provide this service. I have a full CO2 pressure ram that needs certifying. I also need to know the pressure to which it needs testing. As I will have a 1000psig bursting disc, this would seem to be a sensible test pressure. It is also about 120% of the likely maximum system pressure. I am happy to be guided by others.
    Is it the steel 100*140 you got a few years back?
      Wow! You've got a good memory. It was made for me by Mario deJongh about 10 years ago.
        That ram was build to cope with 105 bar/4500psi hydraulic, static pressure.
          Thanks for that information. I guess that I need a piece of paper to say that. I really don't know what proof is required of me by those inspecting my robot.
            You're talking to Mario (maddox) As for certification, I don't know if anybody certifies custom components....for sure it will be difficult to find someone who would risk testing an unknown component and giving it a certificate unless they are really confident the component is well made etc...
              I guessed that it must be Mario. No-one else would know the dimensions of my ram. There must be other roboteers running full-pressure rams. Perhaps they could tell me whether they had any problems or need for certification.
                My certification capability evaporated with the change of job earlier this year.
                  HPAC (http://hpac-armourlite.co.uk) might be able to help you with pressure certifications. They're running a little slow at the moment because Trev's in hospital, but they've certified some of my old pressure components to 300 bar before.
                    Thank you Robert. That is an excellent solution to my problem. I have rung them. They will test it next week and can do it while I wait. They will provide a certificate. What is more they only charge £40 and obviously have done quite a few rams for Robot Wars in the past!
                      Great to hear! Yes, HPAC have been around for a while. Very nice bunch of guys - if Trev's there, ask him about his lawnmower tank! (I know him from tournament paintball)
                        Hi Jeremy, did your ram get certified in the end? Trev mentioned Robot Wars parts but I didn't catch him before he went off again
                          No, the ram didn't get certified. The valves were pressure tested successfully up to 90 bar, but the ram leaked very badly around the seal. I am planning to replace the seal, but I haven't done so yet, because of a series of problems, which I am overcoming one at a time. I will then bring it back to HPAC for testing.
                            That's a shame. O ring sealing is never fun, and rarely right on the first or second try.
                            What pressure are you trying to seal? I'm alright with reciprocating O Ring glands
                              I'm trying to seal full CO2 pressure - maybe 60barg. I'm interested in the reciprocating O ring glands that you mention. They sound like the sort of O rings used in my old 16 barg Norgren pneumatic cylinder. They were made with very soft elastomer and appeared to have a lip to seal the pressure. This old cylinder had two seals, but I only need one, as the pressure is at one side of the ram only. I have no idea where to get such seals, nor what the best material of construction would be. Any help would be appreciated.
