I'm ready to build my FW now, but I have four questions about the rules. Does the removable link need to disconnect both positive and negative, or just one, if so, which one? Do I need a switch as well as a link? Do I need a separate switch/link for the lifter (it's not pneumatic)? Lastly, it's a 360â° degree lifter, so how do I satisfy the rule on tethering it with a chain? Thanks.
Clarification on power and tethering.
1) It needs to simply break the circuit. I believe positive is the recommended side to break the circuit on.
2) No, you do not need a switch as well as the link - it would also be redundant as the link must be done last
3) No, if your using a common power supply throughout the whole robot you will only need 1 link. Separated power sources may require seperate links.
4) You need to lock the lifter in one position with a bar. The bar must prevent any movement of the weaponry, however each case is unique in regards to how this is achieved. The bar must be removable without touching the robot, or getting close to active components.
Can you give me the rule by its reference number (ie 1.7), or via quoting it?
Flippers dont need a chain, however note a 360 design is more likely to be regarded a lifter than a true flipper - and thus may not be regarded as high speed. This would be for clarification with the EO, however in most cases for designs using components like you will likely be using, they are not considered flippers.
True flippers will near always have two attachment points, the hinge itself and the recoil retention (Ie Bungees or the ram itself).Last edited by Garfie489; 30 April 2017, 14:22.
https://www.facebook.com/AblazeComba...type=3&theater
Notice the chain on the axe head? - look around at other axe heads and youll notice they all have some form of wire connecting them to the shaft.
In my opinion, it wouldn't be against the rules as you're allowed to use things to lock your link in place provided the can be unlocked/unscrewed by hand without tools. Best to flag it up to the event organiser arena marshal if you do though, because I used one in the past and the marshal didn't realise, ended up pulling the wire out the link rather than the link itself
I would point out though that sometimes these clips aren't enough and with a large enough impact they can come undone.
Your best bet IMHO would be something like that paired with a sliding link door so that it retains the link from popping out - since it wouldn't require tools to slide it it'd be legal still.
