Okay, using my new bot for some charity work and looking at making my own arena. Just wanted to run it by you all for obvious H&S and practicality.
The venue is in a field, so thinking of getting about 4 wooden pallets and nailing MDF sheets on top for the floor. Using corner brackets attach lengths of 4by2 or something similar as the side walls. Finished off by 4 gates posts outside each corner of the arena with polycarbonate screwed between them. Also thinking of getting a marquee to base everything inside in case of weather.
Obviously NO SPINNERS, but that should be okay for Lifters and pushers. Not sure about axes and pneumatic flippers!?!?
Will also run all this by the event committee and land owners.
Thanks
Thanks
