Hello Roboteers.
Can you please help me! I just want to make sure I have interpreted the rules correctly…
I am running a low pressure system…
I was unable to find a screw in isolation valve for the co2 extinguisher so I have left the lever type and plan to bolt this open with a wing nut (lever clamped shut)
This then goes into a compression fitting adaptor using the nut that came with the extinguisher, (I couldn’t identify this thread)
Then into a hydraulic elbow, then to a ball valve to act as an isolation valve for the cylinder.
This will leave the adaptor, and elbow pressurised (until the wing nut can be removed and the lever shut)
I had planned to use the quick release so that I can remove the canister and also use this for filling, however, I realised that I cannot use the quick release, as this has the potential to leave the quick release to ball valve pressurised, so I plan to replace this with *something* (probably just a screw fitting) to join to the regulator.
After the regulator I have an air fuse for the low pressure side, and a ball valve tee’d in for a dump valve.
I currently do not have a way of quickly dumping the whole cylinder, as it would have to run through the regulator and escape through the low pressure release.
I have really struggled to do this will off the shelf parts, as I do not have access to pressure testing facilities!
Is this correct??
Is this correct??
