I'm very sorry for double posting, but time's drawing in on my build. I've decided to do a featherweight clusterbot based off 101 and anarchy (named 1.01 and anarchism, respectively). I have some questions, though, mostly regarding the rules around walkers and clusters. Firstly, is mike Franklin on the website? I would like to get his permission first before I make a robot based off his designs. Secondly, does anarchy's mechanism qualify as a walker or a shuffler (I don't believe it has 2 degrees of freedom)? Thirdly, and most importantly, how do the rules work? Can I use the double weight and instead enter both of them at 12kg? Or will it be one 12kg robot and a 6kg robot? I've been pondering it for ages and read over the rules a bunch of times. Lastly, is it still a case of one half being immobilised, the whole thing is immobilised (or a 55/45 split)? I doubt it's been done before, so that probably explains the lack of rule coverage. Any ideas? Thank you, and again, sorry for the double post.
walker clusterbot?
No idea on Mike
It doesn't count under the 2DOF rule.
If you built a 2DOF walker cluster then I guess each half could be whatever % of the total you fancy. As long as both parts were walkers then I see no reason that you couldn't have two 30lb machines in the featherweight class.
Can't remember what the current rules on clusters are with immobilisation.
With regards to the weight advantages, i think the best advice would be to go and look at the rules for yourself - they are publicly available on the website.
They explain the definitions of the weight advantages, and what those weight advantages are there.
Hi Alex,
About your comment:
Robot Wars cluster rule is 55% must be eliminated, and FRA rules, as they stand, have no cluster rules at all! :P
If you look in the Competitions Regulations you will find the following:
Clusterbots
Robots that have two or more independent fighting segments, if one segment becomes immobile the complete machine will be deemed knocked out.
So Matt is correct, I hope this Clarifies.
Thanks,
IanLast edited by ian_humphrey; 4 March 2017, 21:33.
