Radio gear and licences
  • Radio gear and licences
    Hi there, I been reading through the FRA build rules and I found some elements relating to the radio gear that has me puzzled and my dyslexia doesn't help but my question is if I use the 2.4GHz DSS radio frequency, which the build rules recommends, how does that insure each robot's receiver will connect to the right transmitter?
    My other question is in regards to 4.1.2 in the build rules, it says I have to get a licence from OFCOM to use my radio gear, is this for all types of radio frequencies that the FRA allows? is it for all weight classes?
    What is the exact name of the licence? so I can look it up.
    sorry if I'm asking silly questions but I want to make sure I understand everything within the rules before I even dare start work on my first feather weight robot.
    You carry out a process called 'binding' to ensure each 2.4GHz DSS transmitter only talks to the correct receiver.
    You will not require a licence from OfCom in order to use your 2.4GHz DSS transmitter. 2.4GHz is in the Industrial Scientific & Medical (ISM) band which is licence free.
    Nothing wrong with questions, but check to see if they've been asked before using the search function. There's a lot of answers to the common questions on these forums.
    Hope that helps!
      I take this 'binding' process is done by having each transmitter and receiver turned on one robot at a time.
      so in theory the radio gear my ant weights use could be use as long as they are a 'DSS' transmitter.
      yeah thanks, thats made things clear.
        Different manufacturers use different spread spectrum protocols so it's not quite that universal, but generally, yep, you have the right idea
        (you usually need to put in a plug or press a button on both reciever and transmitter to do the binding process - it's pretty foolproof though!)
          Oh ok I'll keep that in mind, thanks Joey
            Yeah I have noticed the plug in function while looking for a new transmitter and receiver.
            thankfully I have already found ones that have had positive feedback in the forum, even a receiver that has a built-in failsafe.
