Hi all,
I have recently been working with sheets of 4mm hardox 400 and presumed the fumes given of during welding and grinding were about as dangerous as normal mild steel.
But recently I found out the hard way that it can be dangerous to humans, Ive had burns up my arms witch I presumed were from the light given of by the welder but then went rather dazed after welding which I couldn€™t explain. Also I€™ve heard of cases were Peoples skin dries out and they get a fever.
Just thought I should post something to tell people that this wanted material is dangerous to work with, and that you should take as many precautions as possible when working with it (common sense I know but it sometimes gets forgotten) Is there a dangerous chemical in Hardox that we should be aware of? I hope this stops someone becoming ill.
Dave
Dave
