FP buffer tank thickness
  • FP buffer tank thickness
    What is the recommended wall thickness of a full pressure CO2 buffer tank in aluminium?
    Approx outer diameter of 60mm if that helps.
    Thanks
    The wall of a 12oz paintball tank is on avarage 4mm.
      Thanks, thought it would be thicker than that.
        The smaller the diameter, the thinner the wall can be.
        A 2 kg fire-extinguisher can be up to 10mm. The bottom and neck are way thicker tough.
