Yeah, I'd agree with everything you've said there, Craig.
What is a walker?
How the heck did that thing walk! Surely it would topple over? Either that or Gary is having us on... hehe, wouldn't surprise me. If we look back at all the robots in RW then Millennium Bug, Anarchy, Stomp would all be illegal. In technogames then Scuttle wouldn't pass, Ulysses would fail to.
The only true way it seems would be to make a machine like one of the 4 legged Mech-warriors... which would be dam expensive and difficult.
Either that or someone bites the bullet and goes for something like Mechadon... but NST would have it in bits in seconds!
I think it seems to be gravitating towards less that 100% extra for a cam walker, maybe 25% or 33%. That way most of the extra weight would be used in the walking mech and mean that you couldn't get an extra big weapon as a result.
Hi Gary
Your quote
"Here's a true walker!" So we can deduce that for you, a true walker is one that doesn't work! I'm joking naturally.
I think we have made some progress. My aim is to have a set of clear tests that confirm the Walker badge under the FRA build rules
I am looking for the minimum (for simplicity's sake) to satisfy the criteria set out in the current rules.
1/ It is supported only on it's legs during its walking or turning phase.
2/ Two degrees of movement must be proved, possibly by showing the gait can be adjusted on a leg Step height or length if necessary.
3/ can anyone think of other tests relating to the rules only, not what you think should be their.
My 2 cents. A "real walker" needs a movement that you see as 2 circles, elipses or multi point movements in 3 dimensions. Up/forward and sideways.
Up and forward alone won't do, as that could be seen as a shuffler. Or in other words, a Walking Rig. "Easy" enough to build. And if done well, not needing extra weight to be as good as wheels, except the powerconsumption due grip.
Mechadon is a prime example of a real walker. Stomp, Anarchy, Scuttle and Clawed Hopper are variants on the shuffler principle.
Ok, a bit of a leap of imagination, but say several of these devices were attached to a chassis, and each one given a foot.
Would this be a true walker in people's opinions?
I disagree that the rules say you have to be able to adjust the step length, I interpret than as meaning you must be able to make the leg go up and down and then separately make them move backwards and forwards, do you could have it so it has a set height that it can travel up and down due to a cam based mechanism, as long as the up and down motion is separate from the backwards and forwards motion.Originally posted by craig_colliass View Post2/ Two degrees of movement must be proved, possibly by showing the gait can be adjusted on a leg Step height or length if necessary.
I am not sure if I am understanding you fully but you also seem to suggest that you have I be able to adjust each leg individually which agin I don't think is set out by the rules.
Just my interpretation
