BE CAREFUL when using or testing high power pneumatics...
  • BE CAREFUL when using or testing high power pneumatics...
    http://www.plugenplay.nl/WJ/ontwerp/...titled(WM).wmv
    lol!
    (just copy and paste that whole address inc the end bit into the navigator)
      ok, that doesnt work.
      try this one :
      http://www.plugenplay.nl/WJ/ontwerp/grav2hit.wmvhttp://www.plugenplay.nl/WJ/ontwerp/grav2hit.wmv
        I was waiting for the part when you went airborne - I almost wasnt disappointed
          and another one :
          http://www.plugenplay.nl/WJ/ontwerp/grav2hit2.wmvhttp://www.plugenplay.nl/WJ/ontwerp/grav2hit2.wmv
            Fiesty b****r isnt it?!
              Guys what do you need to do to a hydraulic ram to make it suitable for full pressure use?
              Thanks
              Regards
              Ian
                a bit offtopic...
                change the o-rings.
                  Some dont appear to do anything apart from give it a good clean to get rid of all the oils and relubricate with a non flamible lube.
                    What is the life expectancy of that lighting rig in the 2nd video?
                    Tom
                      getting shorter and shorter Tom
                        WJ..... not sane at all.
                        but we all knew that anyway.
                        Q. how do you retract a 4 tonne pnematic flipper?
                        answered by builder of most powerful flipper in robotwars history
                        A. stand on it and jump up and down a bit. Kinda like Wile E Coyotee does in roadrunner.
                          Sooner or later he gets autodarwinated...
                            WJ,
                            As you know Ive now got a 100mm diameter full pressure ram similar to the one you had - thanks to Mario. What type of bungee(s) did you use to return the ram. I noticed on that second video clip that the ram had not fully gone home when the robot started moving. By the time that you got it to RW7 you had no problem at all with the return stroke. Any help would be appreciated.
                            Jeremy
                              a non flamible lube is not required.
