Rule 12.2.1 (Entanglement)
Peter, I was only pointing out to you what possible judges would make of it. I would, so that means others can too. Your reasoning about the rules is faulty.
See: If you look at the rules you know that 12.2.1 nicely covers everything... even a rope, cable or net. Also take a look at 12.6, any cable you would want to use will be too short to be effective anyway and you will need that robot to be able to dis-entangle itself from the other without cutting the cable (because that would make it an untethered projectile) !!!
The no grappling is implied in the rules about entanglement devices, but it is also a long-standing tradition (and it was a rule enforced by Mentorn !) that you should not hold your opponent pinned down for longer than a minute.
So, with this point of view, the fact that you would sacrifice one of your 3 robots in the cluster to actively entangle the opponent seems rather odd. The nice thing about clusters is that one might be able to hold the opponent for a short time long enough for the other to make a solid attack, but would also force the opponent to choose a target and become one at the same time.
Your reasoning that a cluster robot can immobilise itself on the opponent without being counted out simply isnt going to work.
