Hi All,
Matt of Team Plumb Crazy alerted me today about a potential safety hazard when using the Sidewinder with the Magmotor or other 4-brush motor with the Left and Right motor outputs connected to the brush pairs.
Basically the problem is in Brake mode at zero speed command it is possible to get a battery voltage across the windings of the motor. When connected with Left and Right Sidewinder outputs connected to the brush pairs.
This voltage will be at full battery voltage but running through the coils in a non-standard way so the motor may spin at 1/2 speed.
It is recommended that you run the Sidewinder only in Coast Mode or do not connect both motor outputs to a single motor unless you know the brush pairs are isolated.
Chris Baron
chris@robotpower.com
Need Low Cost High Performance Speed Controllers?
Visit chris@robotpower.com
Need
Chris Baron
Need
