Hi Im hoping to use a mini compressor in my feather combined with a pressure switch to run the flipper at 10bar, I realise that i would need an 11 bar release valve but my saftey concearn is over adapting the compressor to connect to the phnumatic system in the bot.
It seems that the least modification would be to aquire one of the commonly avalible male hose tail bspt fittingings to use on the bot phnumatics, remove the tyre valve adaptor from the end of the compressor hose push it on to the hose tail, secure with somthing ( such as a jubillee clip ) and away I go. But will it pass the tech checks for saftey?
