Elsewhere on the FRA site, you may have seen that Im working with James Baker on some guidelines for Spinning Weapons.  We have a neat way of assessing the Kinetic Energy in your designs which shows how fast we would let you run.  We only need to make a crude assessment of Style (mass distribution) + measured figs for actual Mass & Dia.
Now, at present the FRA are NOT sanctioning use of spinners except under controlled conditions in Class 2 arenas. James and I want to set sensible rules that will allow more spinners, albiet with a limit on permissible rpm.
We suggest that you start designing them with alternative drive systems - one geared down for live events, and another geared up for serious combat. You never know, the reduced spin-up time with a low ratio might even be an advantage ! Please note, that we do not anticipate permitting electronic speed limiters (but would allow reduced voltage).
We need to collect as much data as possible to decide where we should set the level for different arenas. For example we believe the most aggressive spinner is up at around 38KJ, with the most well know in the region of 16KJ, and Feathers peaking at 5-6KJ.
We have some experience of 6KJ in Jonnos arena, and want to collect as much additional info as poss to help establish challanging, but manageable poower limits.
Please post details here, or if you dont want to go public, then send them direct to me or James.
We would like to see Basic Dimensions of the spinning element plus its Mass and anticipated RPM. If you have a calculation for KE - then please post that as well.
Thanks,
Kevin S
Thanks,
Kevin S
