Rule 6.3 The Link
i think that mentorn have to look at the way in which the audience enter the stands. if a robot was to exit the arena and, worse case senario, it got through the outer curtain then the only way for the audience to exit would be onto the same floor as that robot. i think the audience should enter the stands from the rear up steps. the stands should also be a few feet off the ground so that an out of control robot wouldnt smash into the front row. i think they should also seriously consider giving the audience an evacuation procedure, like in an aircraft, as unlikely as they are to need it i think the audience should be informed if the worse should happen so that a mass panic doesnt follow. this could be given between battles as there is 15 minutes where the audience are just watching old fights etc.
perhaps also a polycarb fence in front of the audience which is only about 3 ft highish to give some protection, again incase the worst should happen as the current audience have nothing but a few feet of floor in front of them.
