How many entries so far? At least 40 (80% of the planned 50), but how far off the total are we?
FRA UK Featherweight Championship 2014 hosted by RoboChallenge
Binky was hit full force my Little Hitter and its 2mm Grade 2 Titanium got dented but no were near punctured. Conker 3 had 3.6mm of Grade 5 Titanium on the top. That should stop everything. The only worry is Grant's new axe machine that can in theory go through 4mm of Grade 5 but I doubt that it will actually be able to put all its power down to make that a reality.
All that said, Carnicus has, i think, 6mm HDPE top armour and it was fine. Bent but unpunctured and good to go again.
Our machine took several hits from LH3 (pneumatic axe, powerful) with just 6mm HDPE top armour, and had no issues, only chiseled the plastic a little. Hence this year I am using 5mm HDPE!
(I expect it to get quite badly damaged and am just going to have try and out-drive the opponent)
Hi,
I can say with all words what is fight against an axebot LH2 and LH3
I use 5mm Aluminium 5083 and yes, it makes damages!! Never made "holes" on top, but left serious hits... ATM i'm in a 1-1 against LH, first time he hit the top and the ESC out of their place, entered on drum and obviously, destroyed ESC.
Last year i fixed the problem of the ESC, had a 3min fight against LH he completly discharged the air on top of Galactus, i won for points.
I can advise you (like grant said), if you use a minimun thick plate on top, dont worry about "internal" damages. HOLD all pieces inside and IF you can, to reduce "stress" on shafts of drivetrain use something underneath your robot lilke a "chock", so when he hit your top the "pressure" is dissipated to ground across the chock.
Im not worried about axebots, im worried with this:
Just make sure you declare that at the weigh in.
BTW: 8mm thick steel lid on Satanix, minor nick marks from LH and Tinyhurtz. I did find out either 720 or Drumroll managed to bend a corner when it hit the top horns..
6mm HDPE on Hell's Angel took the blows, plenty of deep cuts but none went through. HDPE is lighter and cheaper than polycarb, something to bear in mind.
Hmm, I might be in a spot of bother with 2.5mm Stainless then, if it manages to get a good hit and damages my motors. Tempted to have a removable lid for axes, made of 20mm HDPE or something. Means I'll no longer be invertible, but against an axe I'm not entirely sure that's such a big deal. Of course, if I get put in a first round battle with an axe and a flipper, that's a whole different story...
Originally posted by daveimi View PostTiny Hurtz didn't get thru my 1mm steel armour but rattled wires out of the speedo. You'll get dents from the big hammers but you'd be unlucky if they got thru. Gaffa tape your connections and give yourself a bit of air gap and you'll be reet
