How would we arrange transport the other side? Rent?
I'm comfortable driving on the wrong side of the road, but too young to rent cars from most places.
Plus currently don't have a robot to take, so can't commit myself to going.
As far as we're concerned this is still happening. Money allowing, that is. If we go we'd drive up in our motorhome, as we did for the champs. It may work out cheaper to fly, so we'll see.
There is the potential that a few could come with us from a pickup point to the event.
Hi Marien, Thanks for that. As written the rules forbid brushless motors, but the rule set is 7 years old. Is it still the case that brushless motors are forbidden, only the named motors are allowed and 40 MHz control gear is required?
The rules concerning motors have not changed. It is not so that only the named motors are allowed, but you are not allowed to go over the dimensions set out in the document (which is essentially a 700 size motor) and no rare earth magnet motors or neodymium. Brushless is still not allowed either. So any brushed 540 size can motor, 600 size, or 700 size motor that is not of a rare earth/neodymium type is allowed.
2.4GHz is allowed as well as 40MHz, but 2.4GHz is preferred.
Hi John, I normally read the German version, which is up-to-date. The English version seems to be slightly out-of-date, but only just.
Like Leo said: no brushless yet, 2.4 GHz is preferred and 40 MHz allowed.
Voltage for drive and weapon: 12 V max, except wenn LiFePO4 (A123) are used, then 4 cells are allowed.
Voltage for valves: 24 V max.
