Rc Wars Series 4 Championship - Sept 18th
This topic is closed.
  • Rc Wars Series 4 Championship - Sept 18th
    Dear Friends
    Rc Wars will be hosting the Series 4 championship for featherweights on July 18th. You are all welcome to enter this event which will be held in Wrexham. Up for Grabs will be a fantastic Trophy for the top 3 places and of coarse the Rc Wars Champion Title.
    Please post here if you wish to enter this event or email Rc Wars. All updates about this event will be posted here in the near future!
    Series4@rcwars.co.uk
    Hope to see you there
    Rc Wars Boyz
    James and Jamez
    I should have the CNCd Micro-Maul evo ready by then... Im in... (you allowing discs?)
      We are allowing most discc. if you are entering a spinner please add your stats of it here please
        were interested, put Alpha and G3 down as maybes. Also this might be the launch of Delta.
          Can you put pimp down please, also pimp 2 will be there aslong as the motor arrives in time. By the way, pimp 2 is a vertical spinner.
          Joe townsend
            hi,
            new KENNY should be done for this event please put me down
            thanks
            kenny
            teamkenny
              (Micro-Maul evo weapon=)
              Drill motor rated at 20,000rpm peak (will probably only get to around 15,000rpm) driving a 7cm diameter disc of a 1:1 ratio timing belt drive (disc weight 500-600g).
                Guys, Im not going to be able to make it Im afraid. Its the same day as the Wickstead Park Roaming Robots event. Missed the last one and Ive been kicking myself all year as a result. Not going to miss a robot event at a theme park again !
                Sorry - hopefully next time !
                Ed
                http://www.teamstorm.comhttp://www.teamstorm.com
                  Were interested - should have the kinks worked out in Arrowhead by then.
                  Ed, Wicksteeds been moved to September so you can still make it.
                    Thats a shame Ed. i did make sure that this event wasnt covering any other. I think the wickstead is september some time.
                      http://www.fightingrobots.co.uk/discus/messages/10/247.html#POST8183http://www.fightingrobots.co.uk/disc....html#POST8183
                        Oooh, didnt realise that
                        Put Storm Horizon and MiniStorm II down then !
                        Ed
                          ministorm???? thats it time for mini Tanto
                            I see 2 possible robots for a grudge match there?
                            Thanks for the entries so far guys, some fantasic (well, all fantastic actaully) robots there, may have to be tea boy for the day to avoid getting trounced at my own event
                            keep em coming, you will want to be a part of this one.
                              Sounds good Ed. could you post the specs of your spinner please.
