Stephen,
The end time is not fixed, if you have to leave at 4pm then no problem. There are no shows, the event is on all day.
The RR list is the correct one, the orginal ones on here we just from posts, RR list is actual mails and sign ups
Ed,
Loads of room, you coming for a few beers on the Saturday night
as well as the main comp, are other fights going on aswell such as; tag team, flipper frenzy, spinner frenzy etc?
new alpha wont be done in time, will have to drag the old one out again (im sure i retired it 8 months ago!), G3 has had a few mods done, Merlin will just be an empty chassis as new one is under way.
Humm... wouldnt it be better for Tag Teams to be paired out of a random draw then at least there is a lower chance of unfair/biased pairings and also allows weaker bots to work with a stronger one to achieve the prize/championship.
There is a main comp, but if you would rather do other stuff then no problem. Basically guys its about having an enjoyable day and putting on something for the public to watch.
I think a battle of the boxes on wheels is called for or in Micro Mutes case the brief case on wheels.
