yep windows sound recorder
Every copy of windows has it
A few little notes
Make sure your sound card is set to what you hear for recording microphone settings. For some reasson my laptop doesnt have this option but my PC does.
Make sure the recording quality settings are good.
In windows sound recorder go to file/ properties.
In the properties for sound click on convert now.
Under name change the settings to CD quality.
Ok when your ready to start:
Play your favorite music on the PC
While your song is playing, record with the sound recorder. It has about a minute max record time.
Stop recording when its passed your favorite bit.
Choose the section where you want to start and click edit/ delete before current position
Go ten seconds later and click edit/ delete after current position.
And your done.
Dont forget to save it and name it something suitible so Stu doesnt have to go through a million WAVE1.wav or MUSIC.wav
problem with adobe audition is that it can be a bit overwelming if no one has done much audio work. Working with the time line ect.
Also not every one has it so I hope you not suggesting they do anything illegal. *GASP*
lol
Having problems with Venoms battries. been cycling them all day to try n get them to charge but its going nowhere. only get 50mah in max :sad:
I do have some other battries but they are a higher voltage so we are taking Venom into electronize for emergency surgery on the speedos to get them to run at a higher voltage. Dont know if it will work, if it doesnt sorry i wont be able to make it. hate pulling out :sad:
