13th May 2007 Roaming Robots - Aylesbury
This topic is closed.
    The event starts at 11am, and runs until 4pm.
    A niced relaxed event with as much time in the arena as you need to get your robot tested and refined without the normall pressure of a full on event.
    Info will follow to teams on thursday most probably.
    Very busy at the moment.
    John
    http://www.RoamingRobots.co.ukwww.RoamingRobots.co.uk
      jonno can you make sure you have a sledge hammer on board to re-shape envy. i am doing a re-build after this event ready for northampton event. although i have to book of work for northampton now cos i thought the event was a sunday might not be able to attend. should be ok tho cos i need to thrash dtk with new improved NV
        oh and if anyone is going who has some hardox for sale can you please bring it along. i need some cheap hardox. go-on you know you want to bring it. no good sat on the shelf doing nothing when it could be on new improved envy.
          is that to stop all the edgehog holes shane
            ALL.....there are no holes from edgehog mate just a broken piece of 6mm polycarb. tee hee hee. i know it was turned down i need it for the front and the flipper as it takes a lot of hammer.
              thats right, we damaged your hand not your robot
                Why do you need Jonnos sledgahammer when you have Thor?
                • #23
                  now theres an idea Leo.
                  • #24
                    its ok having a big hammer, but can Jason hit anything..... ill leave you to ponder on that one !!
                    ** News Flash **
                    Me and steve spent a whole hour on ripper tonight.... with steve on the end of his welder... which means it will work for nearly 2 minutes, instead of the usual 1 Watch out !!
                    • #25
                      edgehog says yes.... hes very bent now
                      • #26
                        Might bring Terrorhurtz along for just one fight to try out the new Lithium batteries. We havent got the proper chargers yet, so wont be able to re-charge.
                        Might not be able to make Northampton, so this would be a good chance to test the new batts out in combat. Ive run THz around the PCWorld car park - took a total of 6.3Ah out of the four packs in about 5 minutes and they barely got warm. Looking good.
                        John
                        • #27
                          ill pop along, but no tanto as controller is yet to be fixed so no point in bringing it along
                          • #28
                            oh go on craig, just pop it in your pocket and bring it along
                            im not even at the event mate, just saw another chance to make fun of Tanto for being so small. but you know Rachels theory about robot size?
                            • #29
                              nice work MR REID Tillyewe2 suffered a great deal from yer axe not only did you chop out the cross member at the front but well lets say the top main beam it had a slight bend to it ... but now ,,,,,, yes you guest it you bent it and snapped it clean out too
                              • #30
                                thats ok Pete, thor did some pretty nasty damage to edgehog too, well done Jason
                                It is telling, that since joining xbotz, Edgehog has not yet been in the arena with Thz.... maybe oneday... well see.
                                (Message edited by jamesb on May 10, 2007)
